I have a 2003 Dodge Ram 1500 and tried installing a remote stater (Clifford 4105x) myself after watching a bunch of videos and reading install how-to's and wiring diagrams from places like 12volt and bulldog, but it didn't work - doesn't even try to crank, and I'm stumped. Here's what I did.
I was just trying to get the bare minimum working first, just the starter side
Remote start 6-pin connector:
On remote starter -> On truck
Red 12v input to pink/black
Pink/white output to 2nd ignition/accessory circuit to red/white (16 gauge)
Red 12v input to red/white (large wire)
Orange output to accessory circuit to green
Purple output to starter to yellow
Pink output to primary ignition to blue (16 gauge)
Remote start harness:
On remote starter -> truck
Black/white neutral safety to black/white on ignition harness
Violet/white tach to green/orange on fuel injector
Brown brake shutdown -> white/Tan above brake pedal
Main harness:
Ground to screw on dash support/frame
Nothing happens when pushing remote start button other than the light on the fob lights up while holding the button.
I read somewhere that said the output to accessory circuit that is orange coming off remote start box needs to go to both accessory wires on truck (large green AND small orange) so I took another quick splice connector and made an opening in it so it could run two complete wires through it parallel and spliced that into the orange wire of the remote start box as well.
No change.
I didn't use any of the other wires of the 9 pin harness other than the ground bc it didn't appear I needed them just to get it to start. Itdoesnt have factory alarm and not trying to setup horn or parking lights just yet or trunk release of course. Or even the anti-grind. It does have a white/blue that says activation input but all I found on that was that if you touch that to a ground source it will start the vehicle just like the remote, I tried that but nothing happened.
So I started checking my quick splices and they appear to be fine. The 12v ones are getting constant 12, the accessory and ignition ones get 12 when the key is in run position. The starter gets 12 when key is forward cranking the vehicle. The brake one gets 12v when pressing the brake pedal. All tested while using the ground I made for the unit so should also prove the ground is good.
After hours of scouring the internet I'm stumped, near as I can tell none of those connections required relays or resistors, except maybe the part about the accessory circuits off the 6 pin connector needed to both be connected to the wire coming out of the remote starter box? Based on all the diagrams I'm finding it's wired right but clearly something is wrong.
Anything I connected wrong? A wire I missed?
Long post I know but any help is appreciated.
You need the wiring for the truck to know where exactly to splice in the wires. "run" ignition on and "start" are the two most important circuits .
Discussion Starter #5
Yeah I went to 12volt.com and bulldog and got diagrams and write-ups of the wiring for this truck. Everything looks right except maybe the accessory output. It's looking like I need a relay for the 2nd accessory wire.
