1 - 17 of 17 Posts
Im going to be changing the differential fluid and have Permatex Red RTV Silicone laying around. Would I be safe using that? Or is better to get some Permatex Ultra Copper like the member did in the how to?
Devil's Advocate
yep that's the right stuff, I used it too with not ill effects
Discussion Starter #4
Sweet, thanks
Devil's Advocate
I though red DTV was better because it was made for higher heat temps?
Discussion Starter #7
So far so good with the red stuff, but I will keep an eye out.
Acts 2:38-39
Yep, I used the red stuff also. You might have seen my howto for the Powertrax LOCKRITE install.....
Mopar makes a gray Gear Lube RTV you can get at the stealership. It's made specifically to stick even if the mating surfaces still have gear lube on them, so you don't have to be so picky about cleaning off all of the old stuff. It's what I use, although I think other brands have also come out with their own gray RTV in recent years.
Discussion Starter #11
Davb673, sorry man I missed that one. but will take a look.
Claw, thats what was used on a 98 Ram that I also had to switch out the gear fluid on, since it never had that service done before. The grey gasket is more thicker and I will use it next time around, but the red gasket is doing its job on mine and on mine dads 98.
I prefer the purple with green sparklys in it
Labrador Retrievers rule!
I've normally use the blue w/silver sparklies for diff covers.
The red w/copper sparklies is better than the plain red.
Gotta luv them sparklies...
Moab Tested
The best stuff I get is free from work. You name it, I got it on a shelf some place at work. :D
I use gaskets, no mus no fus use it over again
Devil's Advocate
even with a gasket you should use a little rtv for a better initial seal
Whatever you use, just make sure it is made for constant contact with gear oil.
1 - 17 of 17 Posts
