So I have 03 2500 no power at all except red flashy light on dash.i went threw other talks about this but could not find how to fix
Discussion Starter · #2 ·
Does anyone have the answers.on how to fix this problem I've tried disconnecting bat.does not work someone said somthing about key color .mine is grey .whats the diff.?
I can't be positive, but my neon has a spare key without the chip in it and it has a security measure that if you try to use it the car will start, but immediately die and there's a red light that'll start flashing on the dash. If your key isn't the original that could be the problem
If the red light is flashing it is indicating the security system has immobilized the vehicle. The key used is not recognized by the ignition security system.
It could be the cable from positive battery terminal to starter. If you have a set of jumper cables, run one cable from +battery to +starter. If the truck starts, replace the positive battery cable.
