1 - 10 of 10 Posts
Team EH.
Well my wife bought me a Recon Xtreme tailgate bar. My flat 4 pin and my 7 pin trailer connectors all have power. I have plugged the 4 pin from the bar into my trucks 4 pin. I have hooked up all the wiring that comes off the bar. But the bar will not light up at all. Is my bar dead? Is there any way I can check out if the bar is dead?
Hook it straight to the battery. There should be a wiring diagram that came with it so you know which wire is which.
GetALittleMudOnTheTires
good luck with it, my first one was $#!T so they sent me another one and this one isn't any better
Come on down to the new house and I'll take a look at it if you don't get it figured out Jeff. :D
NEVER DOUBT THE DEMON
check your grounds on the plugs on your truck, ive seen this before where the ground isnt hooked up and your trailer you tow grounds thru the contact thru the ball, my first led bar did this when i got it and thats when i found out about the ground
Team EH.
Discussion Starter #10
Will do Rye. Havent had much time to look at it. I may just come down to your place and check out your new house and get you to give me a hand if you dont mind.
1 - 10 of 10 Posts
