1 - 3 of 3 Posts
I am just about finished with the install of my Python 1400XP. I am having trouble re-arming the factory alarm. I have been told that it is supposed to rearm when i hit the remote lock, but it does not work with the Python remote. The doors do lock, but the dome lamp does not turn off when the doors lock. Do I need to connect the factory rearm (-) output from the Python? If so where would this be connected?
I am your Father
My advice:
Permanently disable the factory alarm by grounding the wire coming from the lock cylinder in the drivers side door.
Then Find the correct door trigger wire. You went to the dome light wire, which has a delay on it. The actual door trigger will be instant.
You only need one alarm.
1 - 3 of 3 Posts
