AS with many other posters, our 2005 Magnum has had the ongoing problem with the rear windows only working now and then. More recently, the power door locks and mirror adjust stopped working as well.
We took the car to a local TV Repair/ Auto Electronics guy and after lots of hunting, he finally said let's check the wiring in the boot that runs between the firewall and driver's door. He could not get the boot off the firewall, so pulled it off the door and cut the bottom of it open to gain access to the wires.
FOUND THE PROBLEM! There were several wires that had been broken down in places and were not always making contact - explaining the intermittent window problem, other wires were broken completely. Once those were repaired, everything works great finally! So if your rear windows are a problem, check this out to see if it solves your problem.
