It was filled up to the top. Where is it comming from ? 3rd brakelight ? Rear window seal ? Door seal ? I realized i had this issue on my 04 just before i traded it on this one. Now it has it too. Help please.
Check the back window. My dad had a similar mystery water leak on his 97 Ram and it was the back window seal.
But it's good to know about this because I too have an 08 QC.
Can i use silicone caulk & seal that big space between window & seal, or does window have to be removed to fix ?
Id check the third brake light first. I took mine off one night and that was the first night in weeks it actually rained, I looked the bext morning and that storage area wasn't filled with water but it was soaked...
Discussion Starter #5
3rd brakelight is now sealed with clear silicone. Still leaks-now what ?
Premium Member
You and friend need to take the truck to the car wash. Get your friend to hose-down the truck while you check the inside with a bright flashlight and towel.
Brandon
had the same problem and it was the satellite antenna that was leaking
I'd check the vent flaps on the back of the cab. You'll need to remove the seats to get to them. If one's stuck open or the baffles are bad, water could easily get in there.
