Well Sprocket, it appears to me that you're still running your stock LSD. Therefore my advice to you would be to check the remaining fluid first. Full of very fine metal chips??
Also shine a flashlight through the fill hole paying close attention to the carrier cap. Do you see a fresh groove??? If you see either (or both), then forget about the pinion seal as you have broken clips in your LSD. Since I noticed 4.56's & a locker in your 'soon' list, this would be the time to do both.
