Here's the deal, my 1999 D has 165k on it and still runs strong. I noticed the other day during an oil change that it appears that the rear main is starting to leak a bit.
You know the dilemma,at 165k do you drop the trans and change the seal or if I'm going through all of that, drop a crate. How much are fastman engines? He must be a busy guy, haven't heard back from him.
With fears of a worn crank, rounded cam, worn heads, and not to mention the fuel, oil, and water pumps ages, it is probably in my best interest to replace or rebuild. Thats where my knowledge stops...I would want basically a stock engine with only a few internal mods, (step out cam, steel crank, aluminum heads, and maybe one of those FM throttle bodies). Where should I look to find this stuff?
Thanks,
