1 - 7 of 7 Posts
the rear differential feels like it sticks occasionally after stopping the fluid is dark brown like thick muddy water is it the old fluid causing the sticking and should i change it? 99 durango 53,000 miles 2wd
If you have a posi rear end, the fluid is suppose to be changed at 30K.
Do you tow? Or go off-road? If so, switch over to a synthetic fluid.
75w140 will be the best choice.
Can't hurt to change. Put in 75W90 synthetic. You should be able to find Mobil gear oil at any local parts store.
Hummer Recovery Vehicle
look on the drivers side axle. you will see a tag. it will tell you if you have posi or not. mine says 9.25 open meaning 9.25 gears and an open differential.
i believe a posi will say 9.25 LSD
1 - 7 of 7 Posts
