1 - 3 of 3 Posts
2001 dodge 3500 24 valve has anyone replaced the rear axel seal and if so how hard to replace also oil leak an the shaft for the power stearing pump is this hard to replace
Bob M
I had to pull the rear hubs to do the brakes on my '92...ended up having to replace both axle seals. Just pull the rear hub/drum, pry out the old seal and press in a new seal.
I don't know about the power steering pump seal...sorry.
Blowin n' Goin
Are you sure its the power stearing pump? It could be that your oil blow-by bottle is fuell and is splashing out. Have you been checking the power stearing fluid to see if it really is the pump?
And axle seal is pretty straight forward, just got a lot a disassembeling to do.
1 - 3 of 3 Posts
