My question is i just changed the rear axle fluid and drove it around the block as I went to check the fluid level,the fluid began to ooze out ,did i fill it up to much or do I have to let it set awhile to check?
The level on my 2003 is suppose to be like 1/2 to 5/8 of on inch under the fill opening. I used 2 quarts plus 2 oz in mine. (9,1/4 rear end) That got me about 3/8 to 1/2 inch under. I would let it sit and check it again. If you overfill it they say the oil will aireate (air bubbles in oil) and maybe cause problems down the road.
Dan
get a turkey baster and suck some out if your over filled. ive never really been on the dot accurate with it either. just always topped it off best of luck!
