1 - 11 of 11 Posts
i bought my truck used and dont have the stock window sticker. whats the best way for me to see what my stock gear ratio is ? mine is an 05 quad cab, 2wd, hemi if that helps
the good part about that is if i got 4.56 gears it would be a huge difference in performance, bad parts are the 4.56's would kill my gas mileage and top speed
If you dont plan on going faster than say 115mph in the 1/4 mile, then you will be fine with 4.56's. They will make a huge improvement for you on the street and from what I hear, some have even seen better mileage with the 4.56's as long as you stay under 70mph.
hemi-dad said:
better mileage with lower gears ? that would be great. so is 115mph the top speed on the street also with those gears even with a programmer ?
No...115or close to is about where you would shift out of 3rd depending on tire size...and at the track, you want to cross the traps in 3rd gear.
Discussion Starter · #10 ·
wow, 143 in a quad cab ram is movin. so not much change in fuel economy for normal driving huh ? i REALLY need to do that and get an auburn LSD. those with some 17" x 10" wheels and tires should make a big difference in my off the line performance
1 - 11 of 11 Posts
