1 - 3 of 3 Posts
I could have swore the shakey shakes were coming from the rear brakes........
So I turned the drums, new shoes, lubed everything up and I still get the shakes when coming to a stop. Not bad.....but still annoying.
Could it be my front rotors??....geeeesh!
Yes, your front rotors could be warpped.
That's why I like Dodges!
I have had the exact same problem. I ended up going out and buying new rotors. I had the rears turned and it didn't cure it. i thought it was the rear also. i haven't put the new rotors on yet, but i'll let you know when i do. They were only 55.00 a piece plus i had to go out and get the 1 11/16" socket to remove the darn things. i'm sure if you replace yours it will fix the braking problem.
1 - 3 of 3 Posts
