Hi all, I am attempting to replace the rear axle seal on my 2000 Ram 2500 5.9 gas. The sticker in the Glove states its a "Dana M60 HD" I assumed I could go to Rockauto and get the correct seal for the Dana 60. I ended up getting the Centric 41768000.
This doesn't seem to work and I do not know which seal to get. I assume the gold part is the seal I need to push out correct? Second picture is the seal i bought on top of the bad seal..
You need to get the BOM# on the axle...
Depending on the # the seal # is below it. This is actual dana/spicer #'s so if you get another brand they will have to cross reference it.
66155 606156 606205 606206 606714
35313 43146 35313 43146 35313
Thanks, I just went out and checked and it is showing 606240 2
I am searching web now to find out how to find the axle seal for it.
Discussion Starter #4
It seems sooo many parts stores want to give you the 9.25 axle seal. Its hard to specify, I think I may pull the trigger on Napa and get part# NOS 28754
It actually gives dimensions so I may measure diameter tomorrow. We will see.
