spindle will not affect your ride quality in the front, they use the factory coils which is what gives you your ride. if you change the coils most offten they are softer than stock, in the case of dodges though, it moves the lower control arm closer to the bump stops causing it to bottom out hard. if your only doing a 2 inch front drop get the spindles youll be happier.
thank you tim
pm me for kit prices.
