1 - 2 of 2 Posts
I have an 02 Dakota w/4.7L motor (39K miles). When driving, the engine will suddenly lose power and sputter as if it isn't running on all cylinders or something. Eventually it will end up stalling. I have to let it sit for about 5 min before it will start again. This is a major annoyance, and not to mention when it stalls out the ABS light comes on and stays on because the CAB module loses it's memory. I've cleaned the IAC.
I really don't want the dealer to troubleshoot this... help!
You need to check the fuel psi at the rail. Also check the spark plugs.
1 - 2 of 2 Posts
