1 - 10 of 10 Posts
Hey guys, I know this has probably been answered 100 times but can you put the 3 inch Rancho lift on top of the T/S lift for 5" if total lift?
Just wondering because I found a shop around me that has a few of the kits in stock.
Previously Micash21
in theory yes. if the rear portion of the lift uses anything other than shackles to gain the lift in the rear. i cant remember what the rancho uses for the rear lift. the front will lower your control arms. you can get reindexed torsion keys and get the torsion lift. like i said theough, as long as the rancho lift uses something other than shackles to lift the rear, then you can so the shackle lift in the rear also.
hum, ill have to figure out what rancho uses to lift the back....I may not go with it anyways because it was almost $2500 installed. That is alot of money for a truck that has 115k on it and cant resale for more than $5k.
I think I'll just go with the body lift. Shop will do it for $800 total.
Discussion Starter #5
So, do you think its worth it to spend the $2400 on the suspension lift or, just spend $800 on a BL installed?
^BIG D^
IMO I would say skip the rancho because it is rather small lift for a rather large price. Go with the body lift if all you want is 5" total.
But if you want 8", get the rancho on top of the body lift.
Discussion Starter #7
Yea thats what I was thinking...To skip the Rancho because of the price.
I dont want 8" thats a bit much I think...especiall for a DD.
I think Ill just go with the 3" BL.
The shop that I was going to have install the lift said that they could either do the body lift OR the Rancho lift due to insurance issues they would not install both lifts.
DeeGladiator
for the rear...the best thing to do will be a flip over.
Discussion Starter #9
Yea i know, the rear is easy to lift....I want to lift the front and in no way am I spending money on a SAS. I just want a slight lift for minor wheeling.
1 - 10 of 10 Posts
