ram air on a 4.7L
487 views 11 replies 7 participants last post by  snopro
#1 ·
I'm looking at building a duel ram air on my truck. Want to build my own custom tubes that run down to each fog light in the bumper. has anyone done this?? ive seen it done on a lightning before but thats it?? anything will be helpful. pics if anyone has them
Save
#4 ·
I did it, then took those tubes off when I drove it in a drizzle and it almost stalled my truck out. I got home, turned the truck off and 2 cups of water dumped out of each tube. Right now I got the Y and two filters behind the SRT hood, and will probably use the tubes to go to the foglight holes at the track, but NOT FOR A DAILY DRIVER.
#5 ·
ouch that must have scared the chit out of you bro... i know i was terrified enough when i went to take my cai filter off and found it rolling around in the box... who knows how long it had been off
Save
#6 ·
you think water sucks? I went mudding with my homebrew intake and when I took a break and opened te hood the filter was covered in mud, and some of it got through
Save
#7 ·
Those tubes are pretty much the same as the Vararam set-up, but they are mounted in the bumper grille opening. I wonder since that opening is slightly higher than the fog light opening that it helps with water. I know a bunch of guys with them on their Hemi's and they do not have problems with water getting sucked up the tubes.
#12 ·
Well i decided not to do this mod. To many negative feed back plus i like to play in the mud and water to much. So i just ordered air rams jet scoop instead and powerwire instead
Save
