1 - 3 of 3 Posts
2 things real quick 2005 ram
if an aftermarket deck is installed will uconnect still work?? If not is there anything that will make it work?
Also how in the hell do you get the Dash ring (bezel)so I can take the radio out and see how uconnect is connected? :help: :help:
I dunno the answer to #1. But the answer to #2 is simple. Just remove the screw by in your little hook on the dash. Phillips head screwdriver. Then grab that hook and pull out. You gott pull firmly, the whole center panel comes out simple as that. Just gotta pull firm and straight out.
KB
Hemi2nV
Same here and there are a bunch of clips around the bezel so work your way around in a circle pulling one clip out at a time so you dont break it
What is Uconnect? Clarify and maybe i can help you i have an aftermarket stereo.
BB
1 - 3 of 3 Posts
