Im not exactly sure what you have to do to it. I think all you have to modify is takeing your parts off yours and installing them on the Jeeps TB. It wouldn't be hard but could be a disaster if you loose or break a part getting it apart. IMHO 60 mm is too big for a N/A 2.0. It would have more effect on a turbo motor. Anything over 55 mm is overkill if you ask me. Save yourself the trouble and buy a 55 mm bored ATX neon tb. I got mine for 120$ at Howell Automotive. It was reg 199$ but had a chip in the plastic cable holder.So I got it cheaper. And it works all the same! LOL.
The only time it will make any diff anyhow is at WOT. + you do realize that it means you will use more gas! More air = more gas. I used a dremel tool to port match my 55 mm to my intake plenum. Also used it to polish the tb. You can get a little more out of it if your intake and exhaust gaskets are port matched too.
Hope that helps! Later
