1 - 7 of 7 Posts
LivetoRide
so I woke up this morning in huge snow storm and took off to work...problem is my truck sounded like a souped up WRX and I was like crap all cylinders aren't firing. I check my gauge and I have codes:
p0204
p0304
p2314
injector control circuit 4/cyl.4 misfire
Is cylinder 4 the second one back on passenger side? I am at work and don't have my dodge book with me. It shook like hell and I'm hoping I can limp it back home where I can try to check the connections on coils further. Thanks
Try harder
Look at the plug wires, if you have stock (or installed most aftermarkets correctly) it should be marked.
LivetoRide
Isn't 1 on the drivers side - 2 on the passenger side.. so 4 would be the 2nd on the pass side?
I think that's how I remember but wasn't sure...I'll check them by hand in parking garage and then limp home if I need to and get into it more.
^cool I'll check the wires as well, I have stock.
Try harder
Just checked and I'm 99% sure it's the second back on the passenger side from the front (water pump side) of the motor. Just did some research online, couldn't go to my truck, but I hope this helps.
LivetoRide
ugh...so I went to pull off the coil pack on cylinder 4 to test the resistance and noticed my friggin injector wire was chewed in half! Now I'm tryin to figure out if I can change this myself without getting too involved when its 20 degrees out.
1 - 7 of 7 Posts
