that helps.....so have you decided?RedRam88 said:its a 4x2 QP
RaiderJay, I think even if you had the 305/40's you would have to run the 1/4" spacer with your 4x4 cause technically they should be the same with as your tire and the decrease in height is not going to clear where your rubbing issue is on the top of the knuckle/upper A arm.Raiderjay6 said:With the 45's you would have had to run 1/4" spacers on the fronts unless the 4x2 is different then the 4x4's.
I just paid $500 for my 305/40r22 from my local FirestoneRedRam88 said:I got some off ebay for $800.
Were they Firestones or Scorpion Pirellis?04Laramie said:I just paid $500 for my 305/40r22 from my local Firestone
