I have a 1997 2500 CTD 4X4. I put on 16x10 Mickey Thompson Classic lock wheels and 315/75/16 for rubber.
Tires rubbed, so I got the Top Gun 2 inch leveling kit, 2 inch spacers, but still the tires when I turn either way, rubbing the back of the fender wells. Is there anyway to fix this without having to put a lift on the truck? I can drive the truck just can't make any hard turns.
Thanks in advance.
Big Green
Why such a wide rim with those tires they are 12.50? Also what back spacing are you running.
I think they are 12.40 wide, when converted over using the tire calc. Dunno about using the 10 inch wide rims, that is what the guy recommended and I went with it. As for the backspacing I have no idea, how do I find this out?
The two inch spacer pulls your axle back a little bit. If you don't want to lift anymore some adjustable control arms should help to push the axle forward.
