1 - 10 of 10 Posts
I have a 2000 Ram Sport with a 38" tires. Im basically wanting to know what size gearing I would need for those tires. What would I need to buy? Im pretty clueless in this field so any information would be appreciated. Thanks
I would go with 4.56's. There are a few posts in this section that have a real good break down.
Built Not Bought
Do you have a 1500 or a 2500? 1500 currently the lowest you can go is 4:56. Thats not enough gear for 38's. If you have a 2500 you can go alot deeper than that. Id run 5:13's or 5:38's for 38" tires
go with 4:56...5:13 would be convient if you saw pavement
*never saw pavement
Built Not Bought
I disagree on the 5:!3's if you never saw pavement. I drove with 5:13's with wore out 37's. Wasnt bad at all at cruising at 70 MPH. Remember our trucks have a .69 OD Thats a 31% RPM reduction in 4th gear
One day at a time
I have a 03 Ram 1500 and I'm going with the 4.56 gears and Auburn Gear limited slip. The company I'm getting them from said I should get them next week (user crossing fingers) sometime. The tire size that I have is 32.25 " and would go with the 4.88 gears, but they won't be out until late 2005 (Randys RingandPinion). Now with your tire size I would definitely might would wait until the 4.88 comes out. That is a tall tire compared to mine like 6 inches bigger. In a previous post I saw 5.13 gears. I have not seen that available for th 9.25 rear ends and I've looked at many sites 4.88 (coming soon) being the lowest. If anyone wish to correct me on this I would like to know, because I would like to go lower than the 4.56s. With that tire size you need to go low as you can so you will get the performance back. Also with the gear change I would get the Master install kit I think I would rather do that and might have some stuff left over rather than having the mechanic calling around trying to find parts that he will need.Good luck!
Built Not Bought
You're correct, the deepest gear available for the 9.25 is 4:56
Randy's keeps pushing back the release date fot the 4:88's
1 - 10 of 10 Posts
