1 - 3 of 3 Posts
just me
does anyone know if you can add the steering wheel mounted controls and wheel to a D that does not have them currently? is there special wiring needed? is it just change wheel and connect wires? thanks for the help.
I looked into it and it was pretty expensive. There's a new harness from the clockspring that has the pigtails for the audio controls and the cruise control, that alone was about $150, then $12 for each switch, and then if you get the rear portion of the steering wheel with the holes pre-cut that's another $130. I suppose you could always dremel the holes and if you go through the wiring schematic you could create your own pigtails from the existing clockspring. I figure for all the work, I can lift my arm to turn it up.
just me
that's true. i figured that i could maybe find a used wheel from a wrecked vehicle.
1 - 3 of 3 Posts
