my truck always pulls to the left i had it alighned 3 times an they cant seem to get it right but anyway. i noticed the other day when i break it pulls to the left what cause's this?
Great View
When you say pulls to the left is that while driving? If its while driving the first thing I would do is rotate the front tires from one side to the other and see if it pulls right. If it does then you have a tire pressure problem or a defect in the tire. If it still pulls left, find a better alignment shop. If it pulls while braking its because the front disk brakes are not braking evenly. Pull the wheels and check the condition of the pads.
yea i'm gonna do that this weekend, i hope the pads aint bad i only got 20,000 on the clock
also check the tire pressures if they arent all the same the side with the lower pressure your truck will want to drift that way.
Discussion Starter #5
the pressure is good i have them all at 46 i think
