What should I do?
  • New Truck?
    Votes: 0 0.0%
I have a 2004 Dakota 4.7L SLT 4WD. I am having an issue where the motor will sputter/kick when accelerating. This can be at 0-30mph or sometimes it will happen when i reach 40-60mph and will not stop unless I release the gas. If I continue to press the gas the check engine light flashes and then stops after releasing the gas again. There is a loss of power. This issue does not happen all the time. It happens at random as sometimes my truck is running smooth and no loss of power. If anyone has a solution or had the same problems please let me know what you did to fix the issue. I have replaced the Throttle Position Sensor and looked into the EGR Valve but my truck does not have one.
Discussion Starter #2
Still working on getting this fixed. So far by what Ive seen the reason it was kicking was because cylinder 7 and maybe 3 were miss firing. All ignition coils were corroded and some the rubber boot was torn and O rings busted. I have currently replaced the spark plugs with proper iridium spark plugs. Awaiting new ignition coils and replaced any hoses that looked cracked. It was throwing out a code for the small evap leak but I did find the cracked hose. I will be cleaning the throttle body as when I took it off it was really dirty.
Now I am currently waiting on the air manifold to cylinder head bolts to come in as 2 of them snapped on when removing the ignition coils. Best advise for this is make sure you let the bolt set in WD40 for at least a day. After noticing how rusty and seized up they were, I lubed the rest and they came off find after continued lubing. I will be replacing all 8 either way to avoid any other problems later.
I will attempt to replace them this weekend. If anyone knows how to replace them with less hassle please let me know. It doesn't look like a hard fix but if anyone can throw me some pointers, I'd appreciate it. I will keep you all posted on the out come so if anyone else has the same issues.
Registered MOPAR User
If your paid off on truck, keep it.
Still looks great!
Discussion Starter #4 (Edited)
Just an update on the current issues I have been having. I received new ignition coils yesterday and swapped them out. I also added some Lucas transmission treatment. Not much just enough to lube it. Cleaned the throttle body which was dirty. I have noticed the quicker response, no kicking at 30-60mph and quicker shifting. I am sure this cleared up all the problems I was having.
I plan on keeping it as its a beast of a truck.
