1 - 18 of 18 Posts
Okay so I go into the stealership to get an oil change and when they are finished they tell me that because of my oversized tires the front axle seal is is leaking and the axle boots are torn. This sounds like a load of crap to me since my tires are not even that big they are only 33s. Anyone else experience this problem?
Serenity
Well, the stock 275/60/20s are 33" tall, but only 10.8" wide. Any idea how much more the new 33s weigh vs the stock tires? In any case, I am not sure this is a common problem when larger than stock tires are used.
Yeah I don't know how much more they weigh I do know the ones I have on there now weight about 72lbs each.
Serenity
I could understand stress on ball joints, axle bearings, etc, but I would not think that seals would be under more stress, but WTF do I know ;)
Discussion Starter #5
I'm no mechanic so I'm not sure what would cause the boots to tear or the seal to leak, but I have had the truck on some pretty rough rocky terrain not to mention snow.
Serenity
It seems like the size of the tires would not matter in that situation :dunno:
^GM Goodwrench Certified^
if you have ever burried the front end, that can tear the boots spinning them in dirt/ice. i doubt the tires have caused the seals to go bad, but if they are leaking, they should be replaced.
I have had the front end buried in some deep snow and had to be pulled out. But the power steering pump went out when that happened and they should have noticed that when they replaced it.
naw, i doubt they would have, you usually dont see the tear, you see all the lube from inside slung around, and that usually takes awhile, and when i did my P/S pump, i didnt even lift the truck you can do it from the top.
All Around Great Guy
X2^^^^
Why is it that people who put 37's and 35's on them don't have the same problem??? BS....
Once and future owner
Sounds like the dealer is full of it to me. The tires should have no bearing on the dust cover boots on the half shafts. Not to mention they are practically the same size as the stock 275/60/20's that come on these trucks. Have you looked for yourself to see if they are ripped?
thats poop stinky poop
Discussion Starter #14
Yeah I tried to look without getting under the truck but I haven't actually gotten under and taken a real good look. I think they just don't want to fix it under the warranty and are blaming the "Oversized Tires".
I have seen the tear just running on the street- ice,snow,slush gets up there & freezes when you get a real cold snap and it self destructs.
If only I had more $$$
Let me guess, passenger side front axle seal coming out of the diff right?
Discussion Starter #18
I have no idea I haven't been under there to take a look myself and the dealership just said that the seal was leaking and both boots were torn.
1 - 18 of 18 Posts
