Ok my buddy has a 95 2500 with the cummins 12 valve and an automatic trans thats been up graded and the motor has been tweeked a little but heres the problem he installed 370 injectors and now at 1000 to 1200 RPM its got a nasty stumble and if you hold the throttle in the range it just keeps stumbling but if you lift off or get on the throttle it comes right out of it. It also has a FASS 95 gph pump kit on it. so whats causing the stumble.
