1 - 16 of 16 Posts
· You've been Hijacked
For the power wire with a hemi, do you have to take the stock hemi hat off to get to the plug for the power wire? I found what I think is the right plug, but I can't even get my hand in there properly and I don't want to just start pulling on wires.
Also If anybody has a good pic of it installed so I can see where the plug is that would also be appreciated.
Quietpeen, your IAT sensor is plugged into the hemi hat on the front side right where the tube comes from the air filter. Right under the "H" and the 5.7
danimalhemi24 said:
you don't need to pull the hemi hat off. I did come with instructions didn't it?
i bought it used off of KRS, but got the intructions sheet from another thread.
thats where I thought it was but i can't get my hand in there to pull on the plug. Does it slide right off or is there clip like all the other plastic plugs on vehicles?
If I remember correctly, it's a keyway deal. A 1/4 turn in one direction should free it up.
· (_)& (_)& (_)&
it clips, i had to take the pcv tube off to fit my hand there
Shouldn't have to move anything...I did mine in about 5 minutes on my lunch break
Good point...let me clarify: the connector is a clip but I was talking about pulling the whole IAT so I could see it.
Discussion Starter · #10 ·
that sounds like my best option. That way I won't have to worry as much about break the clip. Maybe I will go out during my lunch and try that(who am I kidding....I will be out there around 10:30 :D )
· 25HEMI00
just be really careful not to break the sensor. You will feel the 1/4 turn. If i'm not mistaken it's gonna be counterclockwise. Don't forget to reset your pcm for the new A/F mix.
Discussion Starter · #12 ·
I thought I read to you don't have to reset the pcm with the powerwire
· 25HEMI00
me 2. i just did.
Discussion Starter · #14 ·
thanks for the help guys. I was able to find the right location and get it installed.
· Master Baiter
You don't have to, but it helps to get a fresh start. It'll "learn" quicker.
Stand on the front bumper to get at it at a better angle and it will come right off. I
had the same problem.
1 - 16 of 16 Posts
