My 1994 Gr Caravan 3.3 ltr, SE, Passenger door power window quit working awhile ago. When I finally had time I was able to jumper the window motor, which works in one direction when detached from the door.
I figured I had worn out the switch(s). I replaced the drivers door and passenger door switch(s), but the window motor doesn't work. when detached from the regulater, the driver door switch will activate the motor in the upward direction, but, not down? and when installed back on the regulater, neither up nor down direction work? Unsure of the cause, I replaced the motor, with same results..
Any Ideas of what to check next?...I have a feeling I have been here before, but of course, don't remember. seems like last problem I had was solved with new window motor and regulater, some years ago.
Is there a fuse somewhere?..I looked. no luck yet...:nerd
