1 - 3 of 3 Posts
Can anyone tell me if all the 2005 Power Wagons came stock with the trailer prep tow package? My son just bought one used, and we couldn't locate the brake controller harness anywhere under the dash. It has the additional cooling, and the 7 pin connector at the rear. I can't understand why they would build a Power Wagon without the wiring for a controller.
PW # 5851
I had an '06 once upon a time. It had the brake controller harness as a separate piece in the glovebox, just a plug with wires so you could connect it to whatever brake controller you were using.
Should be able to pick one up at a dealer.
I have an 06, not a PW, my brake controller connector is blue and down by the firewall. On mine if you look straight passed the foot pedal for the emergency brake toward the firewall you will see the connector.
hope this helps.
Mike
1 - 3 of 3 Posts
