A couple weeks ago my power steering quit working. We had a cold spell and it was -40 degrees out for about a week strait. I moved my truck out of the driveway so the plow guy could do the entire driveway and I couldn’t turn the steering wheel. Not wanting to bend anything or break the column I just pulled it back in place and it has been sitting since. I could barely, and I mean both hands putting serious muscle behind it to get the steering wheel to turn either direction from the “neutral” position. I figured just moisture/water in the system and it froze. I have owned power steering cars where the power steering didn’t work and you had to fight the fluid to turn, this is much, much worse. I after about 45 seconds each way I was able to muscle it one direction and then back in the other direction. Once you got it moving it would be difficult (like it would be on a car with failed power steering pump) but not impossible like when first started. If you let it sit for a few minutes it again would “freeze up”. I let it idle for about 30 minutes to see if it would thaw. It didn’t work. Then I put it in the garage but to no avail. I bought new tires this past Thursday so this morning I took the truck into town to pick them up, mount, balance, and install them on the truck. This morning it was still “froze stiff”.
I finished doing my tires and took my truck to my dads shop to look at the power steering system. He looked at it and said maybe it was the shaft. He went and got a pry bar and sure enough the pulley moved in and out about 1.5-inches!
No biggie, but I didn’t feel like doing it. My dad convinced me to just get it and fix it so the truck doesn’t sit for another month waiting to be fixed. I called Advance Auto Parts and they had a Cardone remanufactured lifetime warranty power steering pump with reservoir. I bought it and thankfully it was a pretty simple swap. I filled it up, started the truck, topped it off and pulled it out of the shop for a quick test drive.
Once I pulled it out of the garage I did some tire testing which was just stopping in the middle of the slick hill in front of the garage door and driving up it. I tried it a couple times and once in reverse. I can't believe the difference these tires make. I also put the driver side into a snow bank at a stop and then drove through it for about 50 feet and the truck didn't struggle or spin at all while it pushed through it. Once I get the limited slip installed it'll be capable of more than I'll put it through.
After about three minutes of my new found traction & power steering bliss I pulled around to the front of the shop. While taking the sharp turn entering the parking lot I heard a 2-second squeal and lost my power steering again! It was 9:00pm was a little frustrated, tired, and hungry. I decided to call it a night and hopefully they have another power steering pump in stock so I can change it out tomorrow. I also hope it was simply a defective pump.
Thinking back at how stiff it is without the pump makes me think maybe something else is wrong.
Any ideas?
Any ideas?
