1 - 20 of 40 Posts
Im about to drop my rear end and figured might as well polish my drive shaft. I have a quadcab and I think my driveshaft is aluminum correct? WHats the best way to polish it and is there anything that will keep it looking good for a long time?
Thanks
Maico
Bill3491
Thanks
Maico
Stop in a truck stop and get the stuff the truckers use to polish their aluminum rims. It will be the least expensive and most durable. There is a bottle of this watery liquid, I can't remember the name. It's some kind of etching solution. It will make it really shine.
Boost, you say!?
Be careful. Your driveshaft is 80% cardboard and 20% aluminum wrap. I wouldn't recommend working on it.
MUDDY AFFAIR
ASE approved
i would be verry careful as the drive shaft is a ballanced item, and if you remove too much metal from one side you will get a really bad vibration. i know you said polish it but you will be removning a slight ammount of meterial. also do not knock the balance weight off.
I think unless you where bagging the truck and cutting out the bed for a trick suspension set up you are probably wasting your time. :dunno: I don't even notice my driveshaft and I have a 4x4 mega cab...and the shaft looks like a cruise missile if you get under the truck.
Got 2 Hemis
Somehow, "polishing" and "shaft" struck me funny.
Why polish something that'll be dirty and mud-splattered the first rainstorm? Seems a waste of time, but whatever floats your boat.
i just sanded mine down alittle bit an sprayed it a bright bright silver it looks pretty good for as much as ur gonna see it.
ASE approved
:secret2:well then why wash your truck because the first time you go drive it it will get dirty........
Ramistered User
I say polish away. Not gonna hurt it anything and there's absolutely nothing wrong with a detailed undercarriage
Registered Confuser
dunno how youd polish it, but i painted mine black, and think it looks pretty good.
^GM Goodwrench Certified^
thats only on 2wds, and why would you wanna polish your driveshaft??
DFWRAM
i have a RC adn i took mine off and sanded all the rust off :crazy: man that was alot of rust then i painted it with the duplicolor caliper paint and mow it looks like a brushed aluminium :rck: ppl ask me if it is but its just paint:D and the underside of the truck look much cleaner for car show :rck:
HOW the hell are people looking under YOUR truck???
I RECOMMEND FUKKEN WAX
I like polished cardboard.
1 - 20 of 40 Posts
