Originating Member
I'm open to suggestions here on my '00 Ram Van
thinking about a wheel / tire upgrade
If I currently have 235/75/15 and go to a 17" wheel, what tire size will fit and match things up correctly, so my speedo will still read (fairly) true ?
'98 B2500 Ram Cargo Van
RAM MAN - For what it's worth, my vote is keep it the way it is. I think it looks awesome with the chrome steel factory wheels and the RWL tires on it now. :rck: :rck:
Pete
Do It In A Van
If you do end up with a speedo that's off...you can get the proper pinion gears from Dodge.
275 divided by 25.4 (mm/in) equals 10.83 inches. 235 (the tires on it now) divided by 25.4 equals 9.25 inches. mind you 275 is tread width, not the actual tire width. the tire is a tad bit wider...
Do It In A Van
You might need ta get one o' them there slider extenders Dave. :)
Depending on offset, the front should be fine. I tried my 15x8's on front of my van, with 275-60's, and they fit better then my 15x7's because of the offset. I was checking this because I'm going to put 15x10's on 275-60' in the back, and 15x8's on 255-60's in front. I'm putting on flares and this combination will fill out wheel well just right....
