1 - 11 of 11 Posts
Hey. So a while ago I posted that my a pillar on drier side is leaking water where the cap is for access to the screws.
I still have my fixed ause I'm lazy. But can ware leaking in the a pillar damage anything severely? I was thinking maybe water getting into the fuses or behind the dash.
Please any help would be great. I can go to dodge but the stealership wants 300 to fix. Which is a rip off in my opinion
Dodgezilla
Have you added cab lights by chance? That's usually where the leak comes from. If not then I would get a tube of clear silicone caulk and carefully go around the windshield frame.
Sure the water can eventually cause damage behind the dash...
Registered MOPAR User
Waater will do damage, if you live by the ocean, it'll multiply it faster
LPG Hemi
To the op.
Yep....I used black Silicone sealer to caulk aroung the top edge of my windscreen.
Water was getting in and dripping out of that A pillar bolt hole, you mentioned.
Problem solved.
Al.
+ Hemi Addict +
The third brake light is a common cause of water leaks also....
tbl is not a known issue to leak uo at the front a pillar. the rtv from a replaced windshield is.
+ Hemi Addict +
tbl is known for the puddling in the rear of cab, not for a visable leak coming from the front a-pillar.
1 - 11 of 11 Posts
