1 - 2 of 2 Posts
so my '06 magnum had some weird electrical things happening and i'm still needing some resolution. here's the run-down:
my wife was driving and the wipers suddenly came on without any reason. i ended up pulling a relay and they stopped. replaced the relay, everything seemed fine.
about a week later, i was driving and the horn suddenly came on and would not stop. i pulled another relay it stopped, but the wipers also stopped.
replaced that relay, horn still blowing, so i pulled it for the night.
somewhere in here, something seemed to be draining the battery.
jump-started it and pulled the horn fuse so i could at least drive to work, but still no wipers and now (or at least now i noticed) no rear running lights (no tail lights, parking lights, license plate lights) but brake lights and back-up lights do work. gah!
found a blown fuse in the rear set (#18 20A). replaced it. still don't have rear lights or wipers...
any thoughts? thanks folks, your help is much appreciated!!
Registered MOPAR User
I bought an 05 Maggie last month and while testing the security with a non-skim key, I set off the alarm/horn. do you get any security lights on dash while horn is on?
1 - 2 of 2 Posts
