1 - 2 of 2 Posts
Hey guys just a quick question. Does a pinionangle shim need to be used for a 4/6 drop? The only guy I trusted to do drops can no longer be found so I wanna go at the 4/6 drop by myself.
Oh and 265/45/20's should work right?
Thanks
Batman
The kit you have already has the pinion angle set for a 4"-8" rear drop,you shouldnt have to worry about that at all. The tire size you mentioned will be fine. Just add a set of spindles,rear c-nptch,and stock rear shackles to your current combo and your set,even the Same Nitro Actives will still work(If you have those).
1 - 2 of 2 Posts
