1 - 10 of 10 Posts
Coolest Ram Club in FL
Hey all,
If I was to look for the c-clips in our axles where exactly would one look for them. Pictures would be great.
Thanks
HOTROD
Arnt the c-clips the clips that hold your U-joints in place?? If this is correct there are 8 of them on ur rear axle, 4 in the front and 4 in the rear.
Serenity
Hey all,
Thanks
Charles - if you are talking about the clutch pack retaining clips in the OEM LSD, then you can see them starting at post #19 of the "Another Broken C Clip Poll "year" " sticky thread at the top of this forum.
Discussion Starter #4
Yep thats what im looking for thanks guys
sans sanity
C clips are what hold your rear axle shafts in place. The Dodge 9.25 is a c-clip axle and it has two c clips. If the c clips come out or break the axle shaft will exit the vehicle taking your wheel and brakes with it.
Many people confuse c clips with clutch pack retainer clips for some reason.
Discussion Starter #6
Well then...where can i find the Clutch pack retainer clips to make sure they are all in place and good to go? Thanks guys
Ramistered User
Thought I'd show mine just for the hell of it. Still in place at 40k.
What is the reccomended lube for refill? 03 ram 4wd rear and front diff? I need to change mine, too. nice lookin gears haha
Serenity
FRONT AXLE
C205F - Mopar Gear Lubricant 75W-90 (3.5 pints)
REAR AXLE
9 1/4 - Mopar Synthetic Gear Lubricant 75W-140 (4.9 pints)
If you have the limitied slip unit you also need 4 oz of limited slip additive, so you would need to add 4 oz less Gear Lubricant so the total comes to 4.9 pints. You can also use Mobil 1, AMSOIL, Royal Purple, etc as long as you use 75W-90 in the front and 75W-140 in the rear. The front does not require synthetic, but it works fine.
1 - 10 of 10 Posts
