just like is ask's i have a weird issue where the truck will start to not idle.. been doing it since i bought it.. already replaced the IAC and no change.. and cleaned the throttle body... no change... so what gives? thinking it might be an ECM failure.. so we happen to have a cash for clunker 97 ram like mine but its a mexico truck.. was gonna snag the ecm and the throttle body... just to see if it helps... any ideas if i can swap them?
iam assuming by your name you have a 98....my 98 had a digital odometer....most 97's dont....so no you cant swap them as mileage is store in the pcm...tb you can if the linkage looks the same , which it should
EDIT........WELCOME TO DT
no i have a 97 ram.. my race car/ toy is a 98.... and thanks
Just a tip 98Mystics, make a Signature line with all your truck info so it's easier for people to answer questions. Year, model, 4x4or 2wd, at or manual trans.
