88 w100 318 tbi.
Just got to start installing some new sensors found the map has different tabs for the terminal connector.
The part ordered is rockauto MP136
268-22518 came up for the truck.
Original Connector has 2 slots on the outside pins at 90° to the line up on top at +v and ground wires.
The new part has 1 on center pin sense wire bottom 90° to line up and 2nd parrellel to the line up at the +v wire
Question is, is it just a change in the connector or are the terminals changed?
Part ordered was top of list, spectre, but
WVE has same connector as original part.
Any one here can tell me if the terminal positions are different or resistance values so far out that they cant be swapped.
