It may refer to your rear speed sensor located on the rear axle differential pumpkin.
crazys182003 said:hey rowdy I would suggest you open up your rear diff and see if maybe you broke a tooth off your tone wheel. I had my ABS light on and brake and when I replaced the sensor it still came on. Opened my diff and found out I broke a lot of pieces b/c my clutch packs broke and they ended up breaking more.
ROWDY69ER said:MY new sensor on the differential did nothing for the light---i will check on the other stuff a little later---thanks
crazys182003 said:I broke my parts from driving around my construction site. I ended up hitting a rock and broke them. My mechanic said the clutch pack is a normal thing that does break but not the rest of the parts. Once I had everythign replaced and had my light reset it stayed off ever since. I didn't hear a noise while I drove it but when I was outside and had someonelse drive it I heard a whining sound but that was only after about 3-4 weeks of driving with my light on. I got a 2001 Dodge RAM 1500 318 5 speed. Here is a list of the parts I had to buy and replace alogn with their PNs.
PN# Description
52070340AB Seal-Drive Pinion
01820552 Bearing-Drive Pinion
01820551 Cup-Drive Pinion Bearing
52070427AB Seal-Axle Drive Shaft
05010884AA Sealer-RTV
03723148 Cup-Differential Side Bearing
03723149 Bearing Differential
05017438AA Bearing Drive Pinion
03507678 Spacer- Drive Pinion Bearing
04384227 Tone Ring- Sensor
0080754A Posi
04318060AB Lubricant- Axle
56028187AE Sensor- Wheel Speed
Thats exactly how my mechanic explained it to me. And sicne I had broke a few teeth off my tone wheel the abs sensor was not working properly.Big Joe SS/T said:so that tone ring sensor is the actual ring itself and then the abs speed sensor reads the teeth on that. ill have to pull the pn for mine and see if it matches.
Thanks for the info.bigbucks39 said:Hey Ted go to www.moparpartz.com and put in your info i think i ended up paying under $40 for it
