Painting Valve Covers?
280 Views 8 Replies 5 Participants Last post by  06trxhemi
I was wondering what everyone thought about painting my valve covers while i had them off for the cam install. I imagine high-heat temp be sufficient, but if not I'd like to know :) Also, are there any recommendations in terms of application?
1 - 9 of 9 Posts
high temp spray can paint works well and you can get in many diff colors for painting engines. Just clean them really well with something like Carb cleaner to get any oily residue off that paint wont stick to.
thanks, that's what i needed to know.
always here to help :rck:
Powdercoat them...
Post some pics when you get done. I want to paint my valve covers too. What color are you thinking of going with?
red, to match my truck!
i dont know about painting them, they are really hard toget in and out without touching anything and im afrad that you would scrape them against something and then there goes you paint job. powder coating would be cool as it is stronget than paint i would buy the stuff and wait untill you remove them for the cam swap and see exactly how much room you actually do have and i tink that you will change your mind.
I removed the egr tube on the right side and it wasnt too bad,then the left side went even better........as long as he is careful and the paint is dry I bet he can do it with no harm. I would clear coat them myself also for more protection,.
ok good point. i havent removed the egr tube when doing my removal and installs so i can see how that might help. allthough there arealot of wiring harnesses and thing there as well. so you will have to be careful. i do know that i can take 6 weeks preping something for paint and it will still have problems. even if i put 3-4 coats of color and 8-10 coats of clear.
1 - 9 of 9 Posts
