1 - 10 of 10 Posts
where is that at??? i crawled up under my truck and seen like 4 or 5 sensors going to the block and none of them look like the part i ordered.... It's hard to start do you think i broke a vavle spring????
Discussion Starter #2
Anybody???
Previously Micash21
When you attempt to start the truck, does your RPM needle move?
Previously Micash21
The crankshaft position sensor is on the right rear of the block
Discussion Starter #5
It spins over a few times not moving then the rpm gauge then will jump then it cranks and runs real ruff i put it back on stock tune
Discussion Starter #6
Previously Micash21
Yea, passenger side rear.
Ok cool thank's... I just hope it is a bad sensor and nothing else i,m about to be doing a came swap
Previously Micash21
A bad crank position sensor can worsen the way the engine idles, the pistons fire, or the acceleration behaviour. If the engine is revved up with a bad or faulty sensor, it may cause misfiring, motor vibration or backfires. Accelerating might be hesitant, and abnormal shaking during engine idle might occur. In the worst case the car may not start.
Hopefully this cures your issue.
Discussion Starter #10
yea i hope i so to... When the light came on my engine was at about 6500rpms
now it wont go over 3500...
1 - 10 of 10 Posts
