1 - 6 of 6 Posts
I have a 03 ram 1500 slt with the 4.7L it'll run hot about 3/4 the way on temp Guage, sometimes hotter but not all the way to hot... sometimes about 8th of an inch from overheating. Look like there's water leaking from the reservoir tank which has a 16lb pressurized cap. The radiator has a 6.8lb cap.
Things I've done:
New timing chain
Fan clutch
Tstat
Flushed radiator w/ blue devil flush
Blue devil head gasket sealer
And oil change
Replaced all eight plugs and number 4 coil. Due to a misfire on 4.
Plugs 1 and 3 had oil on plugs.
Has 196xxx miles.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Be careful not to get it hot like that all the time you could mess up your heads a big thing on that motor is the thermostat if it's broke or not open right it will claps your hose and over heat
1 - 6 of 6 Posts
