Well I have big problems, it seems like the o.h. console(from ebay) is possesed. First, if you push the left map light the right comes on, then the cargo lamp( in bed) will not work, but both map lights turn on brightly when cargo light switch is turned on. The display does not show anything when ignition is on just BLANK. THe ohc came with a wiring harness that plugs into the drivers pillar nicely, but none of the wires match colors at all. I have 12 wires with the ohc harness and my truck has 9 wires in its A pillar harness plug( no matching colors). The harness and console is supposely out of a 04 QC 4.7L and I have a 2003 4.7L qc ST truck. I need help switching these wires in the plug (if the right ones are there). Maybe it doesn't work because the trucks harness has three wires missing from the plug? Any help will greatly be appriciated.:dunno:
Is there a fuse or relay that is missing?
