My outside temp on the upper console is not working properly. It seems to be reading about 10 degrees high. Can this be recalibrated? Where is the outside sensor located?
EPA's Worst Nightmare
On the Rams it is located above the radiator on the hood next to the hood latch. I would think it would be the same for the Durangos. Your sensor could be starting to go out. Mine reads high all the time when I stop, but that is because Dodge decided to put it above the radiator. Relocating should take care of that problem.
You can recal the sensors. The manual tells how to do this. I can't remember the steps off the top of my head.
I know you can do a gauge check on the dash and recalibrate the compass, off hand I don't remember anything for the temp sensor.
