Hi folks,
New poster here, and also a new owner of a sweet old Dodge pickup!. I recently bought a 1978 Custom from the second owner (I know, wrong year model forum, but bear with me). The original 318 has been replaced with a 440 which appears from the casting number on the front of the block to be an original truck casting from 1969 (4 T 440 E). My understanding is that the E is the 1969 year code, and the T between the 4 and the 440 designates that it was a truck casting. The problem is that I can't find any output figures or specifications for this engine. And the little that I've read suggests that 1969 model pickups did not come equipped with 440s from the factory. Does anyone know what this engine could have come out of (maybe a mobile home engine???), and what a standard performance 440 from that year range would have put out in terms of HP and torque? If you have any information about things like compression ratio, that would also be helpful for me to know what kind of gas/octane booster I should be running.
Thanks all!
shrewboy
Thanks all!
shrewboy
