only my right rear tire spins, which as you all know is not ideal for traction. what did you guys have to buy and install to get it either true posi or a good traction lock setup ?
well your in luck! I have spent the last couple of week researching LSD units. I have narrowed it down to two. Detroit TrueTrac or Auburn HI PO series.
http://www.rearendparts.com/xcart/catalog/542070-p-717.html
http://store.summitracing.com/partdetail.asp?part=dtl-913a368
Those are the best prices I can find for them. Alot of people are also using Powertrax No-slip. But from what I understand, those two are the best! The Auburn uses cone shaped cluthes, and the Detroit is gear driven. I am going to attempt the install myself. However, I have called about half a dozen places around my corner of the world and install seems to be between $250 and $350.
I went with the powertrax no slip when i put in the 4.56 gears. If you are not changing gears, this is a plug and play product. you wont have to remove the gears--just the spiders and spacers. If you are changing out the gears as well , I would go with the detriot or auburn i think
New Project!...Again!
Yes, And I went with the Auburn.... LOVE IT!!
This unit performes perfectly. When I first got it, It seemed a little loose. The more I drive it, the tighter its getting.
